How to Remove the Bulkhead from a Van
- Aug 15, 2022
- 4 min read
Most people doing a van conversion will want to remove the van bulkhead to allow more walking space in the van. This also allows you to move freely between the cab and your living space, and lets extra light in through the front windows. In this guide, I will show you the simple approach to removing the bulkhead from your van.
What is a Bulkhead in a Van?
The van bulkhead is a heavy sheet of steel that separates cab in the front of the vehicle and the cargo space in the back. They're ubiquitous in panel vans as they're a required safety component, protecting the driver and passengers from loose cargo.
Is it Legal to Remove a Van Bulkhead?
In many countries the van bulkhead is a legal safety requirement on commercial vehicles. However, if you're building a campervan you are likely safe to remove it. In fact, many countries require 'free access' between the cab and the back of the van for registration of the vehicle as a campervan. Check the van conversion requirements in your particular country before removing it.
You can find information on van conversion regulations here:
Irish requirements are in this guide.
UK requirements here.
Australian requirements here.
Canadian requirements here.
US requirements differ from state to state
While the bulkhead removal specifics differ from van to van, it is normally a very straightforward process. Be careful when removing the bulkhead, as they're generally very heavy.
How to Remove a Bulkhead from a Ford Transit
In the Ford Transit, the bulkhead is secured to the chassis with several large torx-head bolts (size T-55). When you remove these bolts, you can remove the bulkhead. They are screwed in very tight, so you will need to use a T-55 torx bit with a socket wrench.
How to Remove a Bulkhead from a Mercedes Sprinter
In a Sprinter, removing the van bulkhead is a little different. The bulkhead is secured in place with blind rivets. These differ from bolts and screws in that they're not designed to be removed.
You can simply drill through the centre of each of these blind rivets and the bulkhead will fall out all on its own. To do this, you'll need a good-quality HSS drill bit for drilling through metal.
How to Remove a Bulkhead from Other Vans
The bulkhead in the Renault Master family (including the Opel/Vauxhall Movano and Nissan NV400) are fixed in place with both torx-head screws and blind rivets. You'll need to unscrew the screws and drill out the rivets, as described above.
Bulkheads in the Renault Trafic family (Opel/Vauxhall Vivaro and Nissan Primastar) are fitted with rivets and ordinary hex bolts. The rivets need drilling, whilst the bolts can be removed with a normal wrench.
In the Fiat Ducato family (Citroen Jumper, Peugeot Boxer), the bulkhead is fitted with hex bolts, torx screws, and roundhead bolts. The hex bolts and torx screws are removed simply, as described above. The roundhead bolts need to first be cut with an angle grinder, giving them a slot like the head of a screw. You can then use this slot to unscrew them with a flathead screwdriver.
The bulkhead in VW Transporters and Crafters is secured with torx screws, making for a very simple removal.
I hope you found this guide to removing the bulkhead from your van useful. You are well on your way to a beautiful self-build campervan. Your next step might be to check your van for rust before starting on the sound deadening and insulation.
