Get The FREE Van Conversion Diagram Pack
Awesome content incoming!
Free van conversion diagrams
How to Build Campervan Overhead Cupboards
Storage in a campervan is both scarce and sacred. Building as much storage as possible is a top priority to most van converters. Campervan overhead cupboards are a fantastic way to use up an awkward space and create a lot of storage capacity. In this article, we will walk step-by-step through an illustrated guide on how to build campervan overhead lockers. In the 2023 Roaming Home study, we found that 73% of vans have overhead cupboards installed.
How to build campervan overhead cupboards
Shane, the founder of The Van Conversion, is a campervan professional dedicated to helping people transform ordinary vans into homes on wheels. He authored Roaming Home and teaches The Van Conversion Course, guiding many people through their van builds. Shane also writes The Van Conversion Newsletter, where he shares practical tips and insights. After completing two van builds and living on the road full-time since 2020, he is passionate about sharing his expertise with others.
Design the Campervan Overhead Cupboards First
Before hopping into building campervan storage, it's essential that you mock it up on paper or with CAD software first. Our full guide on campervan design will help you get started.
Designing a van in Vanspace
I highly recommend Vanspace3D for designing your campervan interior - it's a brilliant drag 'n' drop CAD tool specifically for van conversions.
Campervan overhead cupboards are very common. They are a useful way to fill up an awkward space and give you a lot of useful storage. Let's look at how to build them.
two campervan overhead cupboards
Step 1: Fix the Support Beams
First, screw two 2x2 pieces of carcassing timber to the side of the van. These will be the support beams for the campervan overhead cupboards. Make sure to screw these into the vertical furring that holds up your van wall cladding. In my long wheel-base Ford Transit, these were each 120cm long. Learn about campervan cladding here.
Installing support beams for overhead cupboard
Step 2: Create the Front Frame
Next, create the front frame for the campervan overhead cupboard. You can use 2x2 timber for this. The length should match the length of the support beams from the previous step.
Creating frame for campervan overhead storage
The measurements I used for the front frame were 120cm (L) x 35cm (H).
Campervan cupboard measurements
Step 3: Cut Separators
Next, cut out a few separators from plywood for the overhead lockers - these create different compartments within the locker. Two separators (creating 3 compartments) should be sufficient for each campervan overhead cupboard.
Campervan furniture guide
You will need to make four cuts in each separator into which the front frame and support beams will slot, which you can see in the photo below. The top and base of the separator should match the depth of your end pieces.
Creating separator for campervan overhead storage
Step 4: Attach Front Frame and Separators
Next, screw the front frame to the top of the van. Again, make sure to screw into the furring that supports the roof cladding. At this point, you should also insert the separators between the frame and the support beams.
Attaching frame and separators for campervan overhead lockers
Step 5: Install a Base for the Overhead Cupboards
Cut a square piece of plywood to match the dimensions of the underside of the campervan overhead cupboards. Then, screw this base into the support beams and front frame.
Screwing base into campervan overhead lockers
Step 6: Install an end plate to the campervan overhead lockers
Next, cut two end plates for each end of the campervan overhead cupboards. I used pineboard for this as it matches the 'vibe' of the van. The end plate is a shape that matches the contour of my van. I matched this shape to the contour of my walls using a scribing tool, which you can read about in our article on campervan woodworking.
Attaching end plates for campervan overhead storage
Step 7: Install a Door on the Overhead Cupboard
There are many ways to build a door for your campervan overhead cupboard. Explore your options in this article on carpentry for campervans. I chose to use a length of pineboard cut to size. I attached the pineboard to the front frame of the overhead cupboard using brass box hinges. I installed magnetic catches to keep the door shut tight when driving, and installed a nice door handle to finish the whole thing off.
Some people choose to also install gas struts to keep the campervan overhead locker doors open while they are using them.
Gas struts overhead locker
@FarOutRide installed gas struts in their build
That's all there is to building campervan overhead lockers. They're a comparatively simple build but are almost essential in any campervan. With these done, you might like to move on to designing and building your bulkhead storage or a full-sized cupboard.
If you're still confused, check out our carpentry masterclass for an in-depth, step-by-step course on the whole process.
Don't forget to subscribe to The Van Conversion Newsletter for everything you need to get started with your own van conversion. We'll send you a free wiring diagram when you join.
