MPPT Sizing Calculator
Calculate the correct size MPPT to buy for your campervan solar setup
How This Calculator Works
This calculator helps you determine the appropriate MPPT solar charge controller based on your solar panel configuration and battery bank voltage. It provides a detailed step-by-step breakdown of the calculations performed:
Assumptions and Calculations
Here are the assumptions and mathematical formulas used in this calculator:
Total Power (Pmax): The total power is calculated by multiplying the wattage of each panel by the number of panels in series and parallel:
Total Power = Panel Wattage × Number of Panels in Series × Number of Panels in Parallel -
Max PV Voltage (VOC Total): The maximum voltage of your solar array is calculated by multiplying the panel’s open circuit voltage by the number of panels in series and applying a temperature correction factor:
VOC Total = Panel VOC × Number of Panels in Series × Temperature Correction Factor -
Max Charging Current (Imax): The maximum charging current is calculated by dividing the total power by the battery charging voltage:
Imax = Total Power ÷ Battery Charging Voltage (e.g., 14.5V for a 12V system) -
Short Circuit Current (ISC Total): The short circuit current is determined by multiplying the panel’s short circuit current by the number of panels in parallel:
ISC Total = Panel ISC × Number of Panels in Parallel
Need help determining your solar panel size requirements? Check out our solar panel calculator.
