Battery Bank Charge Time Calculator
Determine how long it will take to charge your battery bank given your battery type, size, profile and incoming charge.
Want it all done for you?
VUNKED
In Partnership with
The Van Conversion
Skip the hard part. Vunked sizes your system, sources the right parts, and ships a complete kit to your door — fully specced and ready to install. Faster, safer, zero guesswork.
Build your system with Vunked →
How This Calculator Works
This calculator estimates the time required to fully charge a battery bank based on several key inputs. The calculation is done using the following steps:
  • Total Battery Capacity: The total capacity of the battery bank is calculated by multiplying the amp hours (Ah) of a single battery by the number of batteries.
  • Amp Hours Needed: The amount of charge needed to reach full capacity is determined by multiplying the total battery capacity by the difference between 100% and the current state of charge (%).
  • Charging Time: The time to fully charge the battery bank is calculated by dividing the amp hours needed by the charging amperage (A), and adjusting for the battery type's efficiency factor.
Battery Efficiency Factors:
Different types of batteries have different efficiency factors, which affect how quickly they can be charged:
  • Lead-Acid: 85% efficiency. Lead-acid batteries lose more energy as heat during charging.
  • AGM (Absorbed Glass Mat): 90% efficiency. AGM batteries are slightly more efficient than traditional lead-acid batteries.
  • Gel: 95% efficiency. Gel batteries are similar to AGM but have a slightly higher efficiency.
  • Lithium: 98% efficiency. Lithium batteries are the most efficient, losing very little energy during charging.
Temperature Effects:
The temperature can impact the charging efficiency of your battery bank. While this calculator assumes a standard temperature (25°C), actual charging times may vary depending on whether the temperature is significantly higher or lower.
Charging Profiles:
This calculator provides a simplified estimate and does not account for complex charging profiles, which can significantly affect charging times. For example, most batteries have a "bulk" charging stage where they accept a high current until about 80% capacity, followed by an "absorption" stage where the charging current tapers off to prevent overcharging. The final "float" stage maintains the charge at full capacity with a very low current.
